First post, by liqmat
If there is already a thread about dumb things you have done to your vintage hardware due to, but not exclusive to naivety, ignorance, bad taste, bad vision, double vision (which is not necessarily redundant with bad vision as I am able to see bad things twice), flashbacks, anxiety, tremors, twitches, temper tantrums, diarrhea and/or constipation depending on what pills you took last night, smoking too many cigarettes for too many years or any other bad or good habits depending on how you view the world then excuse me for starting yet another one. I will post here and just talk to myself to blow off steam, which is fine, since I really do like to stare at myself in the mirror since I am so dashing and described as truly handsome by ladies at least twice my age.
Please, all those who are too smart to make mistakes sit this one out. You can compensate for all the small things in your life elsewhere. Thanks a bunch!
My dumbassery wizardry knows no bounds when it comes to hardware I'm not completely familiar with. Combined with an excellent dose of hyperactivity and attention deficit disorder the world is my oyster that wont open.
So let me start with this wonderful deal on a DVD-RW optical drive I found at a local thrift store.
958.65 KiB
I knew I was in for a treat since it was $5 and had no specific company logo or manufacturer's name on it. You can imagine my excitement heightened even more when I powered it up and it announced itself as...
961.17 KiB
Booted up Windows 98 and put a CD into the drive and... nothing. It tried and tried to spin that disc, but it just couldn't muster up the strength. I quickly opened it up and found a mysterious white ring just sitting there at the bottom of the drive blocking any disc that crossed its path.
935.96 KiB
What could this be? Maybe it goes on the bottom? No, doesn't quite fit. Then it must go on the top. Let me also make up the reason it is needed. To cushion the disc as it spins ferociously in the drive so it doesn't break apart on reentry. Glad I solved that puzzle.
So the only way to make sure this magical white ring doesn't fall away from it's host is to super glue the damn thing on. Make sure to apply enough or it could just fly away. Just one more squeeze and that should do it.
959.09 KiB
There, that's not going anywhere. I better wait for a few hours to make sure it sets properly and is rock solid stuck so no force of nature can remove it.
The night sky drops down like a curtain and I decide it is time to enjoy the rewards of my hard labor and ingenuity. Windows boots, the drive opens, I put a disc in the tray and push the button that closes said tray and... it only goes in halfway. If I was trying to create a wonderful prank DVD drive this would be an excellent specimen, but unfortunately I really want it to go fully in. Over the next few hours of cursing and admiring my knack for dumbassery I start researching what removes super glue. This, of course, is after picking away at the now not so magical white foam ring that looks suspiciously like a corn pad for an unhappy foot. It appears that acetone would be my answer if it wasn't for the fact it likes to eat plastic. So I settle in for the night on a nice comfy chair and cozy up with some fine grain sandpaper and sand away the super glue until the plastic disc underneath was smooth like a serene lake hidden away from all the nuances of technology.
Sigh.
Anyway, the story has a happy ending, I did get most of the glue off and it now spins happily ever after. That drive and I had a long talk into the night after all that drama. A thrift store, five bucks and some super glue. I'd call that a pretty cheap date with a happy ending.
Reply 1 of 5, by cyclone3d
Heh.. that white ring looks suspiciously like the foam rings that come with CD/DVD spindles (25/50/100 packs) in order to keep them from bouncing around because, for some odd reason, they always make the spindle container the CDs/DVDs come in just a bit too tall so they have to have those little pads in there.
Glad you got it working in the end.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 5, by liqmat
That's what Luckybob and I concluded in the end on a Discord channel, but not until I tried to forcibly engineer it into the drive, damnit! 🤣
Reply 3 of 5, by retardware
Great thread, reminds me of this one I found when searching for other things.
Admittedly, there have been a few times I felt really embarrassed of my stupidity.
One of the most blatant ones was when in the early 1990s I worked in a leftist newspaper as a fixer.
I was responsible for maintenance, upgrade and constantly fixing system problems in the 150 client workstation network.
Well, some day one of my colleagues in the IT department asked me for a gender changing null modem.
Many of the workers in that newspaper were stoners. I just had returned from a service call, where I got invited by colleagues to share some good reefer. As I was not used to smoke strong stuff, I got stoned like a chimpanzee.
Guess what I built?
I just put two DB25F together mirror-symmetrically and soldered them together.
Later, I was somewhat clear again, the colleague returned and asked me "can this work?".
I looked at the thing, scratched my head and felt very embarrassed, and responded "aww, oops, no..." and quickly prepared a working null modem 😀
Reply 4 of 5, by liqmat
retardware wrote:
Great thread, reminds me of this one I found when searching for other things. […]
Guess what I built?
So let me get this straight. You had a reefer party at work? Dude, what was the retirement package like there? A field of weed in some South American country?
Reply 5 of 5, by SirNickity
I'm not proud of this. But I feel it must be done.
67.09 KiB
