First post, by member
J2 HEADER -It is like on Gigabyte TV Out Bracket pin definition
Multilayer NTC Thermistors Series: ERTJ0ER682 😎
Reply 1 of 9, by Zup
So... what's the qeustion?
I'm selling some stuff!
Reply 2 of 9, by Jo22
member wrote:
https://www.gigabyte.com/MicroSite/12/1au001_e.jpg […]
I'm speaking under correction, but these are..
COMP = Composite aka CVBS
GND = Ground
Y = Luma (Brightness)
C = Croma (Colour)
Y/C is also part of the S-Video connector.
Reply 3 of 9, by member
HI
i searching for pin definition on the J2 HEADER -It is like on Gigabyte TV Out Bracket pin definition- yes or not
woow-£45.00 https://www.ebay.co.uk/itm/S3-TRIO-64-V2-DX-G … nwAAOSwU-pXsxr2
Jo22 wrote:
I'm speaking under correction, but these are.. […]
GND = Ground
C = Croma (Colour)
you are correct 😎
Composite video is also known by the initials CVBS for composite video baseband signal or color, video, blanking and sync
And here is the S-Video and TV-out.virgegx2.jpgi also have to add 4mb EDO RAM to my PCI Graphics adapter
Reply 4 of 9, by keropi
99,999% that is not a tv-out header, the VIRGE chipset needs an external encoder to do tv-out, have a look at the card labeled "Windows multimedia accelerator with TV-Out support based on S3 ViRGE/DX" here: http://vgamuseum.info/index.php/cpu/item/562- … pro-s3-virge-dx
Reply 5 of 9, by member
BUT why it has TV mark to header-
The attachment img_20161010_1438211477612770.jpg is no longer available
My be is for an tv tuner daughter board ....
Reply 6 of 9, by retardware
I guess it is just a marketing trick.
https://www.techwalla.com/articles/how-to-kno … v-signal-output
if it works at all, people will quickly ditch the idea of using that, because of the low resolution and horrible flicker (remember this was in the pre-LCD time).
Personally I guess @keropi is right, as I never saw a graphics card with 4.43MHz crystal, which would be necessary to support PAL. (NTSC 3.58 could be relatively easily obtained via the various 14.318 sources in the PC)
Reply 7 of 9, by Zup
Maybe there is (or was planned) to launch a version of the same board with TV-Out (with U3 populated?), so they can manufacture two models of the same card but only one board.
Reply 8 of 9, by swaaye
Moved to Video.
Reply 9 of 9, by bymember
member wrote on 2019-03-31, 14:50:
BUT why it has TV mark to header-img_20161010_1438211477612770.jpgMy be is for an tv tuner daughter board ....
HERE example of use braket hole
319898_03fb58ab-97fa-461b-86bc-fc666272a95f_1728_1728.jpgfile.php?id=61208&mode=viewovermolded-cable-assemblies-with-strain-reliefs.jpg
