First post, by henryVK
- Member
Dear Vogons,
I'm currently putting together a P1 system and I got a Spea V7 Mirage P-32, S3 Trio32 86C732-P PCI card, supposedly tested, for very cheaps...
Today I got around to installing Win95 and already in the setup I noticed these vertical moving lines across the screen, like interference or ripple. Once I hit the Windows desktop it was pretty apparent that it is pretty severe. Now, I'm 100% certain it's not the CRT so I'm guessing this is an issue with the card? Is this a common issue with S3 Trios? Should I bother with investigating, repair (I have no experience with video cards) or move on to another card. There's a Cirrus CL-GD5446 that I could get, which I understand has similar speed.
Thanks and cheers,
Henry
