First post, by pan069
- Oldbie
Hi everyone,
I have this motherboard, an ASUS p5A-B. I really like this board because it tiny! However, there is a problem though... Look at the CPU socket placement and the AGP slot. Yep, very close. I'm currently using a Pentium MMX 233Hmz. The problem gets worse adding a heat-sink and fan on top of the CPU.
Do you guys have any recommendation for a heat-sink and fan that might fit this config?
