First post, by candle_86
Trio64+ V + PowerVR or Matrox Millennium
Basically in my Packard Bell I have the option of using the onboard Trio64+ V and gaining access to my PowerVR card, its just a VR not a VR2 but it will give me limited 3d acceleration, or using the Matrox Millenium, the other 2 PCI slots are occupied by a Soundblaster PCI 128 and an Intel Pro 100-S Nic, so that leaves one PCI slot.
The PowerVR Card is a Matrox PowerVR PCX1 with 4mb Texture Memory
If I use the onboard though I only get 1mb framebuffer, though its upgradeable to 2mb if i track down a memory chip
Reply 1 of 13, by BinaryDemon
I’m curious, what are the other specs of this Packard Bell? I’m going to guess something like Pentium 166 based on other parts you’ve mentioned. Only because I wouldn't want to recommend using the PowerVR on a 486 class machine.
That said I would totally go the PowerVR route.
Reply 2 of 13, by candle_86
BinaryDemon wrote:
I’m curious, what are the other specs of this Packard Bell? I’m going to guess something like Pentium 166 based on other parts you’ve mentioned. Only because I would want to recommend using the PowerVR on a 486 class machine.
That I would totally go the PowerVR route.
Pentium 166
40mb EDO
Windows 98SE
Reply 3 of 13, by spiroyster
I don't think Matrox made a PCX1, the only PCX1 afaik is the Videologic Apocalypse 3D, the m3D is a PCX2?
Reply 4 of 13, by Rawit
Correct. And according to https://gona.mactar.hu/DOS_TESTS/ the S3 might just have a slight edge in working with the m3D in Tomb Raider. Is the output of the S3 to your liking?
YouTube
Reply 5 of 13, by Scali
I believe the PCX1 chip is marked with D62010GD001, where the PCX2 is D62011GD. So check '2010' vs '2011' on the chip.
This would be a PCX1:
http://vgamuseum.ru/wp-content/gallery/nec-po … alypse_3d_f.jpg
And this would be a PCX2:
https://upload.wikimedia.org/wikipedia/common … calypse_3Dx.jpg
Reply 6 of 13, by candle_86
its labeled D62011GD
The output is fine, and i found some ram to make it 2mb
So is the PCX2 a good card?
Reply 8 of 13, by candle_86
Scali wrote:
Uhhh…. that's a huge can of worms you're opening there 😀
It's not quite a 3DFX VooDoo.
🤣 well early 3d accelerators I wasn't involved
Reply 9 of 13, by gdjacobs
Sometimes.
The PCX2 port of Mechwarrior 2 is the best version.
Reply 10 of 13, by swaaye
Yeah I like that PowerVR MW2 port. The fog on some missions adds a lot of atmosphere.
Leileilol was working on making Quake 3 work on PCX2 once upon a time. 😎
Reply 11 of 13, by candle_86
Well I'm positive my Pentium 166 won't play QuakeIII, but i like MW2 and ive sinced heared about a tomb raider native version also
Reply 12 of 13, by candle_86
so I've decided the slot layout of my 3 avalible PCI slots and 4 ISA Slots
ISA1 - AZT3000 Soundcard/Modem Combo was in the computer when I bought it, will replace with an AWE64 or SB16 later on
ISA2 - Open
PCI1 - Matrox Millennium
PCI2 - Matrox M3D
PCI3 - 3Com 100/10 Nic (Considering buying an ISA Nic so i can add USB to this comp)
ISA 3 - Empty
I tried the onboard, max 800x600 with above 256 colors at the desktop and i can't stand it, also tried a Trio64V+ card I had in my parts bin, same issue don't like it
Reply 13 of 13, by Scali
gdjacobs wrote:
Sometimes.
Yea, basically the card is good, but it's the software support that lets it down in many cases.
It has Direct3D support, but performance isn't that great, and its unique architecture means that certain effects like alphablending may look poor.
Likewise, there's some MiniGL support, but not as widely supported as a VooDoo.
But various early games were modified by the PowerVR people themselves, with native support, and then the card really shines.
