First post, by pan069
- Oldbie
Hi all,
So, I have this socket 7 motherboard which is AT form factor but it also has a ATX power connector. Typical late 90's cross-over board I guess. I usually use ATX power supplies with an ATX -> AT converter for AT boards.
Since my case is AT and the board is AT but with ATX power it makes sense to go for ATX power instead of AT. However, the case is designed for an AT power switch (i.e. the one that's on typical AT PSU's) and this switch doesn't work on the PWR pins for the board. I.e. the AT power switch stays pressed after pushing it. I'm currently using a new (smaller) style reset switch to turn on/off the machine for testing but I'd like to use the actual power button on the case.
So, I'm looking for an AT style power switch (as in the image) that acts like a reset (i.e. comes back up after pressing it).
I have been unable to find them on eBay... 🙁
