First post, by mkfish
mkfish
Offline
Hi,
I've got an old 16 bit VB application that starts out by trying to get a file using the code above. There are several .TXT Files n the local folder.
The app does not find any files.
The DOSBOX Status Window reports
SHELL:Redirect output to FileList.dat
Any ideas why the GetFile$ is not seeing the files and if there is a way to resovle it?
Thanks in advance,
Mark//
