First post, by feipoa
Do DIP-14 crystal oscillators in the range between 66.6 and 70.0 MHz exist? I'm referring to the package size which fits into 386 motherboards. I can find 66.667 MHz and 70 MHz, but not between.
261.46 KiB
Reply 1 of 1, by Tiido
You can get such freqs only in non 5V surface mounted packages. Some modifications are necessary to make these work right (voltage regulator and a buffer chip to do 3.3V to 5V conversion).
