First post, by yawetaG
Today I finally received my Casio GZ-70SP I won on Y! Auctions Japan (the middleman service I used shipped it by ground mail for a completely unclear reason...).
This is a Japan-exclusive General MIDI/speaker combo set that's also meant for karaoke, so I figure I should post some pictures.
It's clearly NOS despite the box having seen better days:
181.14 KiB
158.02 KiB
Mmmhhh...sealed baggies and CD-ROM:
102.09 KiB
130.28 KiB
91.34 KiB
Reply 1 of 11, by yawetaG
CD-ROM with Lana online software (which appears to be some sort of NIFTY-Serve (CompuServe)-based online community software), karaoke software, and Faith serial driver, compatible with both DOS/V and NEC PC-98:
172.35 KiB
156.23 KiB
The CD-ROM has by now been unsealed, so I could have a look at the included booklet. 😀
Casio-branded 9V power supply (100V input for Japan):
152.3 KiB
Serial cable with adapter:
161.74 KiB
Casio-branded DM-5 microphone:
156.93 KiB
The mike feels quite solid. Don't know yet how it is sound-wise.
Reply 2 of 11, by yawetaG
Left speaker with nice gaudy sticker on the front and connection cable on the rear:
121 KiB
151 KiB
100.97 KiB
Right speaker with integrated General MIDI sound module, microphone amplifier, and hardware echo function:
126.02 KiB
127.23 KiB
Reply 3 of 11, by yawetaG
88.18 KiB
The "speaker" connector is for the left speaker. It also has a separate line-in.
Bottom copyright with serial number:
66.81 KiB
I find it interesting that it was specifically made by Casio Computers instead of their music division...
Paperwork:
129.08 KiB
Everything is in Japanese only. Half of the paperwork is for the Lana Online software, the other half for the GZ-70SP proper. Connections quick start guide:
138.32 KiB
Reply 4 of 11, by yawetaG
The Manual is almost entirely in Japanese, except for the instrument lists.
Specifications:
133.6 KiB
General MIDI instrument lists:
172.72 KiB
175.38 KiB
General MIDI drum sets, including Roland TR-808 drum set:
166.35 KiB
148.09 KiB
Reply 5 of 11, by yawetaG
MIDI chart:
115.07 KiB
I don't know how it sounds yet, although IIRC there's a demo on Youtube.
Reply 6 of 11, by SuperDeadite
From my searches, the 70SP has the same MIDI hardware as the GZ-30M. So sound wise, it is a step below the GZ-50M. I have become quite fond of my GZ-50M, and am hoping to get the 30M at some point, just because it is so tiny and cute. 😀
Modules: CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster
Reply 7 of 11, by DevanWolf
Hey, can you please donate that product to me so I can make MIDI conversions/comparisons with that?
My address is: REMOVED
Please send the GZ-70SP to my address. You better do this now or else I won't make more MIDI comparisons!
EDIT/mod comment: Address removed. Not wise to publish your home address in public on the internet. You may never know when it will used against you.
Reply 8 of 11, by yawetaG
Apparently it also exists in a very nice metallic blue finishing (picture stolen from Y! Auctions Japan):
78.72 KiB
Reply 10 of 11, by yawetaG
Haaa, finally tested these with a MIDI keyboard. The sound set is rather uneven: nearly all synth pads are quite good, some excellent, part of the strings are great, while any blown instrument sounds highly unrealistic at best and pretty crappy at worst. The percussion is good to great, but the pianos, chromatic instruments, and anything else with keys are rather boring. The string instruments that aren't great aren't great because they sound like keyed instruments. There's something weird going on with the sustain part of the envelope on patches with long sustain, likely looped samples (in some cases you can hear the tail end of the attack for a bit when the sample loops).
There aren't many options to modify the sound: modulation, pitch bend, main volume, pan, expression, sustain pedal, sostenuto, soft pedal, most available via CC. There seem to be some more options available via (N)RPN messages, but the instructions for that are almost entirely in Japanese without sysex codes.
The microphone volume needs to be turned up quite far to hear anything, and I cannot get the digital echo to work.
Reply 11 of 11, by yawetaG
Okay, I guess this one will need some work: The microphone circuitry falls silent now and then, and the problem with the digital echo appears to be that although the op-amp connected to the digital echo level pot works the digital echo effect is not produced.
