First post, by Intel486dx33
Can I use ceramic capacitors in place of tantalum capacitors on my 486 motherboard ?
What are the pros and cons ?
Reply 1 of 7, by GigAHerZ
Depends, but why should you do that?
A little about software engineering: https://byteaether.github.io/
Reply 2 of 7, by rasz_pl
mlcc capacity is more of a guideline than a hard stat, it changes with bias voltage https://www.murata.com/en-us/support/faqs/pro … /mlcc/char/0005
then you have high defect rate in high mechanical stress scenarios (smd cap + flexing board = actual real world house burning FIRE)
but for motherboard decoupling? sure
Edit: forgot to mention mlcc also like to make noise, and exhibit microphonics, still non issue for old motherboard decoupling
Reply 3 of 7, by Mut
Replace those old tantaluns with eletrolytic caps, they are cheap and reliable. I've always had success doing it.
Reply 4 of 7, by Intel486dx33
I think I will just use the original tantalum capacitors.
Reply 5 of 7, by rasz_pl
there are different uses for different types, cant just blindly swap and expect it to work
https://electronics.stackexchange.com/questio … ferences-in-use
Reply 6 of 7, by gdjacobs
Polymers and MLCCs are both appropriate (and manufacturer recommended) replacements for tantalum caps. Of course, please beware of the propensity of ceramic caps to fail short and generate microphonics.
Reply 7 of 7, by Mut
Tantaluns are prone to fail catastrophically and are not recommended.
Electrolytics and tantalus have similar characteristics.
On the past I had two identical 386 motherboards (I don't remember the model) but from different batches, one using tantaluns and the other one using electrolytic.
