First post, by Guest
Guest
Offline
is there anyway to unbind ctrl +f1 so it doesn't start the key mapper?
would be an edit but can't so whatever:
the reason is because whenever i hit ctrl f1 dosbox closes
In the config file, set another output option (anything but surface). CTRL+F1 will then popup the key mapper, which will allow you to unbind it's own short cut 😀... Which is useless, since it doesn't crashes anymore..
x__X
