First post, by Efren
So i tried configuring this PCI soundcard. there was a similar post about this card but it wasnt solved. I know the soundblaster 16 ISA is the best choice but sadly i havent found any and this is the only one i have. Im just trying to configure the soundcar so i dont mind about other configs. Whenever DOS loads it hangs in the fname: SBPCI.ini. Pictures to clear it out
PD:Id like it to make it work under Windows 3.11 as well
Autoexec:
SET BLASTER=A220 I5 D1 H7 P330 T6
SET SBPCI=C:\DOSDRV
C:\DOSDRV\SBLOAD
C:\DOSDRV\SBINIT.COM
C:\WINDOWS\SMARTDRV.EXE
CONFIG.SYS
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\EMM386.EXE NOEMS NOVCPI
DOS=HIGH, UMB
