First post, by eric1992
I installed XP professional on a Compaq Presario (I'm planning to swap out the case and motherboard sooner or later) but the PC keeps telling me to activate it. I can get the internet working just fine on Windows 10 but on XP it won't load any pages or anything. Even just plugging the ethernet into the PC doesn't do a thing regardless of drivers.
Reply 1 of 13, by BushLin
I assume phone activation still works if you'll never want XP online anyway.
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 2 of 13, by The Serpent Rider
Phone activation does work. But since Microsoft does not support it, it's much easier to download Win XP SP3 from torrents and don't bother with activation at all.
Reply 3 of 13, by BushLin
Also, disable your LAN adapter in XP when you're done... it's a harsh world out there. Probably not sensible to download torrents without anti-virus too, and even then...
Reply 4 of 13, by Baoran
I think it is fine to have windows xp pc connected to internet. Just make sure you have firewall that blocks all the incoming connections to that PC and don't go to any shady web sites.
Reply 6 of 13, by MrGenius
The Serpent Rider wrote:
...download Win XP SP3 from torrents and don't bother with activation at all.
Or...if you don't do torrents(which I personally don't):
EDIT: LINK REMOVED. Plenty of "auto-activating" versions there.
Or...if you want to be a bit more legit(like if you just need service packs and/or updates):
WSUS Offline v9.2.4. Get all your XP service packs and updates all in one go. 😉
Side note: It won't get you the WE/POSReady updates though. Still have to get those via Windows/Microsoft Update(or the Update Catalog).
Reason: Link removed: warez
Reply 7 of 13, by SirNickity
Huh... WSUS Offline. Hadn't heard of that. Good tip.
Still trying to find one of those.. ehhh... "self-activation" methods that works reliably. It really irks me that I have a legitimate, retail copy of XP Pro, box, media, the whole nine yards, but I can't just click the Activate button anymore. I don't like that I ever had to, but now that I can't, I like it even less. Who knows how long the phone workaround will exist. I'm OK paying the piper, but I really want a final solution instead of relying on asking Microsoft for permission to use the software I bought.
Reply 8 of 13, by chinny22
Seems like someone forgot to tell Microsoft, they released another patch just last week.
https://www.howtogeek.com/414804/still-on-win … y-or-get-wormed
Reply 9 of 13, by BushLin
If/when MS ever cut off activation for legitimate customers I don't see a problem with using the same method Dell, Lenovo etc. systems auto activate offline. No need to now though.
Reply 10 of 13, by The Serpent Rider
They still don't support it. They had to do it in this instance, but only because it's really huge exploit and a lot ot ATMs are still using WinXP.
Reply 11 of 13, by chinny22
Who's fault is that?
I'm not complaining, We have a few XP/2003 PC's running industrial machines still worth close to 1 million so its not like they are getting upgraded soon.
but likewise I don't expect MS to support something they pulled the plug on a good few years ago.
Just like dosbox is for games not business programs. if it works hey great but we aren't responsible if it all goes terribly wrong.
Reply 12 of 13, by bjwil1991
I need to replace the hard drive for my IBM ThinkPad R40 laptop with an SSD solution (mSATA to 44 pin 2.5" IDE), 64GB mSATA SSD, and writing the hard drive image I placed on my main desktop PC with Linux and expand the storage to the full 64GB (about 61GB or so).
Reply 13 of 13, by Roman555
For tier-1 laptop-manufactures usually there is an so called Windows XP OEM activation. BIOS of their laptops usually contents a special brand string.
So you just need to get a Windows XP distribution for the brand of your laptop and install. No activation will be needed.
Also there is software utilities (they are maybe illegal) that make OEM version and OEM activation of already installed retail version of Windows XP.
