First post, by ddlt
Maybe I am over thinking this. I am using an old Dos Pos and Barcode Scanner programs with DOSBox. How do I make them run at same time. The POS needs the barcode software to be running in order to collect the data.
Thank You
Reply 2 of 3, by ddlt
My scanner is a stand alone unit that needs its own program running. It uses BC_WEDGE. I think I might have figured it out. It has been many years that I have used DOS anything and my brain was blank. Its coming back slowly. Thank You
Reply 3 of 3, by leileilol
You don't.
long live PCem
