First post, by Dareka
I got the floppy version of Shadowcaster running on Dosbox and it works fine except for one really obnoxious problem. The combat music does not play at all. Instead whenever an enemy hits you or you hit the enemy, the first few seconds of the exploration music keep repeating. I tried the demo and it had the same issue.
Is there any way to fix this?
