First post, by InbetweenDays
- Member
I've just been testing an MT32 which had problems with Prince of Persia (1 and 2). I tried the usual tricks of a slowdown utility and also /delaysysex on softmpu, but no luck. "Hmm, that's right, I had issues with POP2 on the MT32 and CM32 before," I remembered incorrectly... so I checked my other ones and there was no problem.
Then I thought to check the firmware... aha! 1.0.5 not 1.0.7.
So I burned 1.0.7 EEPROMs which fixed it. (Side note for posterity: I didn't have any 27C256s so I used W27C512s with the ROM images doubled. This works just fine.)
I've done some searching on the issue but can't find any info other than that versions prior to 1.0.7 had "some bugs", and for best compatibility 1.0.7 is the firmware to have.
Just wondering if there's a list anywhere about firmware versions and incompatibilities?
It don't mean a thing if it ain't got 5-pin DIN.
Roland addict and founding member of the Association Of Molex Haters
