First post, by mdanh2002
Hi,
With some time recently, I explored how the PCE/macplus emulator https://www.emaculation.com/doku.php/pce_macplus can be used with CodeLite and Retro68 (https://github.com/autc04/Retro68) to form a very good development environment for 68k Mac apps. I have written an article here http://www.toughdev.com/content/2018/12/devel … cplus-emulator/ that explains how CodeLite can be setup exactly for this purpose. Mac apps can be run on various emulators on different Macintosh System software just by changing the project configuration dropdown. Autocomplete is supported as well. CodeLite can also be configured to tail the serial port output file and this can used for debugging purposes.
The article also contains links to download the VirtualBox image with everything set up and ready for you to try out. This is a YouTube video that shows how everything can work together nicely:
https://youtu.be/o3KFNdmM5Os
Let me know what you think.
Building software & hardware: https://www.toughdev.com/
