First post, by TechDeals
Hi all... long time lurker, first time poster...
I noticed the Dell 2007FP has a composite video input and S-Video... neither are important for retro PC gaming as far as I'm aware, however I've been pondering picking up some other older computers from the 80s, a C64 or C128, or perhaps an Amiga... things I missed back in the day being on the Apple II line before moving to PC.
Since I have a 2007FP in my collection, I was pondering if it would be as simple as picking up some older computers and they would "just work", or perhaps might "just work with adapter cables" of some type, or if this monitor is just WAY too new to accept anything they'll output.
I really don't want to eat the space of a real CRT if I can avoid it...
Thoughts?
Reply 1 of 10, by luckybob
welcome!
As a PROUD owner of the 24" version of that monitor, I can say it was VERY handy to have when I play with my Apple II stuff.
Reply 2 of 10, by gdjacobs
luckybob wrote:
welcome!
Pretty sure Dell never made a 24" 1600x1200 VA or IPS monitor. 😲
Reply 3 of 10, by luckybob
ok, I suppose the 2007 is different than the 2008
I have the 2408WFP for the record. It still does have the inputs OP describes, and I stand by my feeling for the display. (svideo, composite,etc)
Reply 4 of 10, by BushLin
Just remember that even the best LCD screens will have some inherent lag and Dell displays aren't usually optimised for response times, the upscaler will have some lag too; so if any of your intended games rely on fast reflexes, you may end up wondering why you're not as good as you remember (other than just being older).
For the systems you listed a 15Khz CRT monitor would work well. Monitors for the Amiga which carry the optimal RGB signal will give the best picture from that system; but tend to have a single input, although that input is usually Scart and switchers are still available. A Sony PVM / BVM with RGB would be ideal with the right cables / adapters as you'd have at least RGB, S-Video and two composite inputs, the smaller ones aren't very bulky and built to last.
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
Reply 5 of 10, by dr_st
The 24" version (2407WFP or 2408WFP) is 1920x1200, and it's VA.
24" IPS on DELL monitors started with U2410.
Reply 6 of 10, by oeuvre
The 2007fp/2007fpb is great for retro stuff. Never had issues with it in DOS or 3.x/9x etc.
Reply 7 of 10, by Windows9566
my 2005fpw died sadly. had composite and s-video on it, loved that monitor till it gave up its ghost.
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 8 of 10, by TechDeals
gdjacobs wrote:
luckybob wrote:
welcome!
I wish they had... for this sort of thing, a 24" 4:3 monitor would be awesome! It seems that 20" is as big as they ever went, including the 21" CRTs which were really 20" viewable...
Reply 9 of 10, by TechDeals
luckybob wrote:
welcome!
I have an Apple IIgs and the Apple Color RGB monitor... that makes me wonder, can I just plug the 2007FP into the composite output of the IIgs?
I was thinking I would need a Apple RGB to SCART cable, then a SCART to HDMI adapter... would be nice if I don't... guess I should go try it!
Does the IIgs still output 15khz horizontal on the composite?
Reply 10 of 10, by luckybob
yes.
do what you want with your money, but I believe it to be a horrible mistake.
#1 scart is European. as far as I understand scart, its the same as the american RBG standard, just a different connector.
#2 if you did have to use an adapter; https://www.ebay.com/itm/132960778930 looks like a better alternative.
