First post, by wiretap
- Oldbie
I replaced the dead TH6887A RTC on my Biostar MB-1433 today with a new Dallas DS12877A. Very easy, only takes about 15 minutes. I hope this short little guide helps you. 😎
Here's the motherboard with the existing (dead) RTC installed on the left-middle side.
Picture of the newly manufactured (2018) Dallas chip, about $10 from Newark:
First, I placed the motherboard vertical with the RTC on my right, and the soldered rear side on my left. I set my hot air pencil to the melting point of the solder, then slowly worked over the pins until everything was melted. Then I used a pair of needle nose plyers to pull the RTC off the motherboard. It comes out very easy with little effort if you have all the solder melted.
Now to clean up the holes which are full of solder. I held the motherboard in the same position, with my soldering iron in my right hand and solder sucker in the other. Heat up one pin hole at a time, and suck the solder out the opposite side. Repeat for all the pin holes. This would be easier if you have a vacuum pump desoldering tool, and would also eliminate the above step. I am cheap so I did it the "hard" way. Nice and clean now:
Next, put a DIP socket into the RTC location to facilitate easy replacement 10+ years from now. Solder it in place.
Finished product:
