First post, by eL_PuSHeR
- l33t++
Hello. It seems cookies used on this forum to show "read" links last too litle. Any ideas?
it seems to be a session length of 600 seconds.
I could increase it if you like.
Water flows down the stream
I have sometimes the problem that I go through the new messages and if there are too many of them or if I write some replies, the board stops to higlight unread messages (and I must guess what I have not read).
If this interval could be increased I would be happy. 😀
Mirek.
okay increased it to half an hour.
why don't you guys check posts date/hour (at the top of the forum you have the time of last visit)
highlighting is not reliable cause it doesn't highlite new posts that appeared while you browsed the forum the last time.
having the same problem, thanks Qbix !
Don't be so hard
Thank you very much, Qbix. 😎
