First post, by pan069
I have this PCPartner board and an AMD K6-2/450AFX. I'm reading through the manual and the board seems to support the K6-2 but it doesn't seem to have a configuration for 450Mhz, the closest available configurations are for 475 and 500 mhz.
What cpu configuration would be best for my board/cpu combo?
http://support.pcpartner.com/support/man/via/895400.pdf
Reply 1 of 3, by The Serpent Rider
Use 500.
Reply 2 of 3, by PC@LIVE
In my opinion you can set the K6-2 450 as the K6-III 450, the only difference is the VCore which must be set to 2.2V, while the K6-III goes to 2.4V.
In the last pages of the manual you will find how to set up the VCore, you can even go down to 1.8V, if you find a K6 + you can easily set it.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 3 of 3, by pan069
Thanks guys. I will try both options and see what happens.
