First post, by Rolandradio
Windows 7 will not boot on the Jetway computer but its working fine on the other HP computer.
Blue screen on boot up: STOP 0x0000007B errors. (HDD driver compatibility)
Why has the Jetway this error and the HP computer not ?
Jetway NF99 D525 from 2010
HP P4 core 2 duo from 2009
Tested with 2 HDDs both with same trouble! (MBR to zero and new formatted)
BIOS: IDE mode not AHCI
2 GIG RAM both PCs
Linux and windows XP has no trouble only windows 7.
Windows 7 is new installed but on final bootup, the 07B error displayed.
Reply 1 of 5, by ZellSF
Wrong forum to ask this question.
Reply 2 of 5, by Rolandradio
Which forum ???
under software ?
Reply 3 of 5, by Rolandradio
Why is this the wrong forum ?
This forum is for running old windows games on NEW (supported) versions of Windows
by Qbix
The Jetway computer is a modern PC that still have an LPT port for the OPL2 Adlib!
GRUB-bootloader with Freedos, Linux, Tiny7
Reply 4 of 5, by Stiletto
Moved to Marvin > Software.
The "Windows" subforum is only to be used for discussion of patches, hacks, registry fixes, etc. that help make old Windows GAMES run (natively) on newer versions of Windows.
You were asking for generalized Windows OS support on hardware, not for support with any particular game.
do the Fandango!" - Queen
Stiletto
Reply 5 of 5, by Rolandradio
Ah, you give me the reason why, Thanx
I take a look under Marvin software.
