Setting Screen Size
First post, by Lenfal_01
Is there any way to set DOSBox screen size. I have been inside the Options file. It has the setting for fullscreen, as well as the Resolution and WindowResolution, but I am not having much luck. I am running Windows 10 Home with 1920 x 1080 resolution. I tried changing the Scale setting in W10, but this did not change the size of the window. Ideally I would like a DOSBox window somewhere between standard size and full screen.
Thanks.
