First post, by a.deutschman86
Hello,
I am attempting to run a Bridgeport milling machine that has a DOS CNC control with DOSBox. I've attached the .zip program.
In DosBox I use the command Z:\>mount a: c:\sx15 and the directory is successfully mounted. I change the directory to a: and can view the directory of files. When I attempt to run autoexec.exe, I get the error "Configuration File 'Z:\CONFIG.BXT' not found:".
CONFIG.BXT is located in C:\SX15 and I can view it in the a:\ directory in DOSBox
What am I doing wrong?
Before I attempt serial comms I would like to get the emulation working,
AUTOEXEC.EXE
ECHO OFF
PROMPT $P$G
PATH=A:\DOS
MODE COM1,4800,N,8,1
MODE COM2,4800,N,8,1
RUN
RUN
ECHO OFF
PATH=A:\DOS
:LOOP
BS
FONTLOAD A:\DOS\BXT.FNT
ECHO Loading Operator Interface...
BXT %1
IF NOT EXIST NEXT.BAT GOTO SKIP
CALL NEXT.BAT
DEL NEXT.BAT
GOTO LOOP
:SKIP
