First post, by Windows9566
My sound blaster pro 2.0 is having 1 annoying issue, it's only in Windows 95, in DOS it doesn't do that, but in Windows 95. it has that issue.
Video - https://youtu.be/BsLuLfXLYH8
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 1 of 31, by Windows9566
maybe capacitor replacing might help, creative used cheap capacitors on them and they didn't age well, and also maybe put blanking plates on the PC to block radio interference.
Reply 3 of 31, by Windows9566
cyclone3d wrote:
Specs of the rest of the system?
Pentium 100
Startech 300W ATX Power Supply
Intel TC430HX
64 MB RAM
Cirrus Logic GD5446
Reply 4 of 31, by JudgeMonroe
Do you have the PC Speaker connected to the SB? If you mute the internal speaker input with the W95 mixer does the noise go away?
Reply 5 of 31, by Windows9566
no, i don't have the pc speaker connected to the sound card, i have the PC case speaker connected to the PC speaker port on the motherboard.
Reply 6 of 31, by georgel
Check power supply of the computer. Check 7809 stabilizer IC on the SB card.
Reply 7 of 31, by Windows9566
georgel wrote:
Check power supply of the computer. Check 7805 stabilizer IC on the SB card.
that power supply is fairly new, i just got it a few months ago. I later put in my Sound Blaster 16 CT1740 and i don't hear any interference unlike the SB Pro 2.0, i also put on blanking plates to hopefully eliminate RF noise. I later put the SB Pro 2.0 in my ASUS VX97 full tower P133 build and I don't hear any RF noise or whining unlike the other machine. It's also on top of the table unlike the P100 PC that is on the floor next to my main Windows 10 PC.
Reply 8 of 31, by TheMobRules
You know, I have kind of the opposite problem... the card has that annoying "thinking noise"/whine when idling in DOS command prompt, but it goes away when playing DOS games or in Windows 3.1. I have that same problem both of my SBPro 2 cards, tried different (good) power supplies, as well as several motherboards to no avail. Strange thing is that even my SB 2.0 produces less background noise, and also like you the 1740 does not whine at all.
I guess it may have to do with how well the motherboard filters out noise in the ISA bus.
Reply 9 of 31, by Windows9566
my main Windows 10 PC even has that annoying thinking noise/RF interference on the onboard sound card, it's worse when i use headphones.
Reply 10 of 31, by georgel
Check the circuit around the 7809 IC.
Reply 11 of 31, by Windows9566
looks ok
Reply 12 of 31, by georgel
Look with oscilloscope!
Reply 13 of 31, by derSammler
Try a different video card or move it to a different slot.
The SB Pro 2 (and all earlier Creative cards) is known to pick up any interference, this was even back then. It's not an issue with it aging. It's just badly designed.
Reply 14 of 31, by appiah4
Does it have a -5V rail? SB Pro 2.0 needs -5V, that may be you rissue.
Reply 15 of 31, by HanJammer
Indeed. I had new SB 2.0 back in the 90s and I could hear bytes chirping in the data bus of my 286 at all times 😉 - it's the same case with every CL card in my collection from similar Era (CT1600 and early, less integrated SB16s)... it was way into 90s when CL started making cards featuring better integration and significantly less noise.
Reply 16 of 31, by appiah4
My CT2290 also picks up ISA bus interference in the form of hisses and clicks on 286-386-486 motherboards. It's just the way Creative Labs junk rolls.
Reply 17 of 31, by Windows9566
the PSU has a -5v rail, thats why i bought it from amazon a few months ago.
Reply 18 of 31, by cyclone3d
The real problem is that the motherboards should have good filtering designed into them. So it wasn't just Creative's problem.
Get a board that doesn't have electrolytic caps or doesn't have filtering caps on the ISA/PCI/whatever bus and you will have noise.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
