First post, by roarkes
I found at the price of 11 $ a Sony sound mixer. It is grey like the first Playstation and has the posibbility of recording sounds, beside sound effects (cat, broken glass etc.). It is simple and on the back it has ports for vhs (i think) video, left and right audio and cd in. In the middle it has a slider for reverse sound and on the left a small lever for backward sound and fade lever.
Somewere on the hardware, it is writen learning. It was made for kids maybe. The sound effects have litlle buttons.
The hardware cable has it is like a vga port.
I didn't took a picture in the triftshop and i don't know what year or the model. What do you think ?
Doom4ever
Reply 1 of 4, by Vynix
Pictures will definitely help, ideally if you can get a picture of the model number of the unit...
Reply 2 of 4, by roarkes
I made some images. I will post them if needed. It is a Video Sound Effector XV-A33F.
Below is a link with this item description. I don't advertise this link, but you will see some info.
I don't know if this hardware goes to a console or a tv set and how it is used. I renamed the forum topic from
"Sony sound mixer with cat, broken glass etc. sounds" to "How can i use a Video Sound Effector XV-A33F ?"
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=200966759636&category=3278&pm=1&ds=0&t=1567208431232&cspheader=1
Doom4ever
Reply 3 of 4, by Vynix
According to the pictures from your link, this thing seems to accept composite video in, so I would assume you could plug it from a Composite source and plug a capture card on the "recorder" end of that thing..?
Reply 4 of 4, by Sune Salminen
It looks like it's for adding cheesy sound effects and overdub any audio (Microphone and CD inputs) you like onto home videos.
I guess the idea is that you put it between a camcorder and a VHS recorder and add stuff as you transfer your recording to VHS.
It has a companion, the XV-T33F:
https://youtu.be/uXh9RXepJSk
