First post, by Intel486dx33
What is Mitsumi drive interface on Sound Blaster ?
Is it same as IDE ?
What type of CDROM does it use ?
Is it same as IDE ?
It has been mentioned both here and in other parts of the internet multiple times. Did you try to search before you posted?
A little about software engineering: https://byteaether.github.io/
the mitsumi drive interface is for early mitsumi drives that use the mitsumi drive interface 😀
The Mitsumi (CRMC-) LU005 is a famous example for a CD-ROM drive that uses this interface.
Other models were apparently the FX001, FX100, FX100D and LU002 etc.
https://commons.wikimedia.org/wiki/File:Mitsu … accessories.jpg
https://de.wikipedia.org/wiki/Datei:Mitsumi_D … _2010-10-17.jpg
