Reply 1 of 44, by DosFreak
- l33t++
"Right-click on Aladdin.exe and go to the Memory tab. Max out Expanded & Extended Memory.
Click on OK to save. Use the .pif or .EXE to play the game!"
or use the VDMSound GUI to configure the memory.
Reply 2 of 44, by Robo
My windows isn't in english so I don't know what is what (Expanded & Extended ).
Reply 3 of 44, by vladr
- Oldbie
wrote:My windows isn't in english so I don't know what is what (Expanded & Extended ).
They should show (abbreviated) as EMS and XMS or use VDMSound + LaucnhPad if under NT (LaucnhPad is in English).
V.
Reply 4 of 44, by Robo
I have a menu only for XMS. Instead of the EMS menu there is a button that if I press it it says that EMS memory was not defiened for my comp. I have WIN98.
Reply 5 of 44, by Snover
- l33t++
I'm going to assume you're running a Windows 9x box.
Replace your config.sys file with this:
DOS=HIGH,UMBDEVICEHIGH=C:\WINDOWS\HIMEM.SYSDEVICEHIGH=C:\WINDOWS\EMM386.EXE RAM I=B000-B7FFBUFFERS=20FILES=20
That'll turn EMS on and define some other things that may not have been in your original config.sys file.
Yes, it’s my fault.
Reply 6 of 44, by Robo
Do I have to replace it?
I have things in that file...
Reply 7 of 44, by Snover
- l33t++
Do you have to ask?
ALWAYS make a backup.
ALWAYS.
ALWAYS.
ALWAYS.
Save your old one as, for example, CONFIG.BAK, and this one as CONFIG.SYS.
Yes, it’s my fault.
Reply 8 of 44, by Robo
That wasn't my question...
I asked if I keep the stuff inside...
I ALWAYS make backup 😀
Reply 9 of 44, by Stiletto
- l33t
Just post the contents of your config.sys file here, we'll be happy to help you edit it. 😀
do the Fandango!" - Queen
Stiletto
Reply 10 of 44, by Snover
- l33t++
Ah, yes, indeed. Just post yer config.sys here and we'll do all chopping and pasting and moving around of your stuff.
Yes, it’s my fault.
Reply 11 of 44, by Robo
here it is:
DEVICE=C:\ESSAUDIO.SYS
device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=972,862,C:\WINDOWS\COMMAND\country.sys
Reply 12 of 44, by Snover
- l33t++
If you would please, what's the size of ESSAUDIO.SYS, and what sound card is it for?
And what country do you live in? (heh...)
Yes, it’s my fault.
Reply 13 of 44, by Stiletto
- l33t
ESSAUDIO.SYS is an audio driver for sound cards/integrated sound chipsets made by ESS Technology, Inc. http://www.esstech.com/
Not sure which one, though. Maybe the Maestro 3?
The Display.Sys line has something to do with setting the system prompt text. Next line does as well.
Country code works out to Israel, believe it or not. Doesn't necessarily mean he/she's there, though...
Stiletto
Reply 14 of 44, by Snover
- l33t++
Seems to me the display.sys line and the country line are just wasting valuable conventional memory.
I need to know how large the ESSAUDIO.SYS file is so that I can figure out whether to use DEVICEHIGH or not. (Though, when I used the SB driver with DEVICEHIGH, it spewed visual funkiness and froze my machine.)
Otherwise, 2DOSWIN's settings should port quite well.
Yes, it’s my fault.
Reply 15 of 44, by Robo
Reply 16 of 44, by Snover
- l33t++
If you're using an ESS audio driver, you've got an ESS card, not a Creative Labs card.
I didn't say anything about Israel, I just said that defining it wastes valuable bits that are needed to load other, more essential devices.
Yes, it’s my fault.
Reply 17 of 44, by Nicht Sehr Gut
- l33t
wrote:And is there any problem with Israel?
Language barrier problem. He is referring to the "country code", not the country.
Reply 18 of 44, by Robo
So do I remove the line?
What does it do? Why is it there?
And my comp has an "ESS, on board, 16 bit" - whatever that means...
Reply 19 of 44, by Snover
- l33t++
Okay. So. Use this.
DOS=HIGH,UMB
DEVICEHIGH=C:\ESSAUDIO.SYS
BUFFERS=20
FILES=20
If your system freezes up when it's loading, go into safe mode command prompt and change DEVICEHIGH=C:\ESSAUDIO.SYS to DEVICE=C:\ESSAUDIO.SYS.
Yes, it’s my fault.
