HWiNFO support of vintage hardware
Reply 441 of 683, by ApostolCV
Hello my friend!
Some time before i get some uncommon stuff. It's a mother MSI 845 PRO V1 (Socket 423) and two CPU for it.
First CPU has SSpec SL57V, second- SL4SG.
First detected by system correct. Butwith second i get some strange results.
In latest version of HW info (6.40 and 6.38) it detects like Quality Samle CPU - QAQ2.
Ok. That's programs are too new. I download older version.
HWinfo Ver.3,35 thinks that's SL4SG,SL4SC. But in the type of graph - Eng. Sample.
Hmm. Much closer to the truth.?
Downloding Hwinfo ver. 1,56...
Ok. Now all is right. SSpec, type...But wait . CPU frequently 11k MHz.
Can it be CPU with edited IHS?
Downwards i add screenshots and results.
    423Result.7z
    14.74 KiB
    64 downloads
    121.63 KiB
    122.1 KiB
    127.18 KiB
Reply 442 of 683, by Mumak
ApostolCV wrote on 2021-01-05, 19:36:
Hello my friend! Some time before i get some uncommon stuff. It's a mother MSI 845 PRO V1 (Socket 423) and two CPU for it. First […]
Hello my friend!
Well, the CPU reports it's an Engineering Sample, hence HWiNFO reported the respective QDF instead of SSPEC.
Please attach the HWiNFO Debug File from the latest version so I can check this in detail.
Also if you're able to get the old Intel CPU Identification Utility you might try if it will report an ES too.
Reply 443 of 683, by ApostolCV
Here it is.
    1.4_v6.40.HTM.7z
    13.32 KiB
    61 downloads
    126.84 KiB
Reply 444 of 683, by Mumak
Sorry, that's not the Debug File. See here how to create it: https://www.hwinfo.com/forum/threads/read-thi … g-a-report.241/
Also try the Intel Processor Identification Utility if you can find it somewhere.
Reply 445 of 683, by debs3759
Mumak wrote on 2021-01-05, 20:37:
It can be found at https://www.techspot.com/downloads/2979-intel … on-utility.html
Not sure if the version on the Intel website works on 32-bit processors
Reply 446 of 683, by ApostolCV
Thanks. Hopes now i make right.
debs3759 wrote on 2021-01-05, 20:43:
Thank's for the link. But this do not support 32-bit CPU. =(
    HWiNFO32.7z
    12.11 KiB
    55 downloads
Reply 448 of 683, by debs3759
ApostolCV wrote on 2021-01-05, 21:57:
Thanks. Hopes now i make right. […]
The list says it does. Oh well.
Reply 449 of 683, by red-ray
Mumak wrote on 2021-01-05, 22:02:
According to that data it seems to me it's an ES.
We'll need to find an old version of Processor Identification Utility for confirmation.
I have lots more fidenus in neither of the attached works
Mine is 100% ES for sure, so CPUZ get's it wrong and also failed to sensibly report the RDRAM SPD + multiplier range. HWiNFO failed to report CPU LFM Min which is x8.
file.php?id=99641
    RW4.txt
    31.03 KiB
    75 downloads
    268.88 KiB
    100% ES for sure
Reply 450 of 683, by ApostolCV
red-ray, thank you for old versions of @Intel CPU U@.
Fidenu25 do not see something special.
Am i right?
    58.49 KiB
Reply 451 of 683, by red-ray
ApostolCV wrote on 2021-01-06, 00:38:
Am i right?
Look at the Frequency Test page. What does SIV32X report on your system?
file.php?id=99645
    119.06 KiB
    not a production processor!
    pidenu47.zip
    4.09 MiB
    54 downloads
    How I know this one works...
Reply 453 of 683, by red-ray
ApostolCV wrote on 2021-01-06, 02:26:
Seems Intel know something about it.
Thank you, I guess we need to figure out why. What ratios does the BIOS allow you to set? With my CPU which is an ES I am offered as below, the range is x8 to x23.
file.php?id=99669
    111.29 KiB
    Intel Pentium 4 (Willamette) 1600MHz [B2] [ES]
Reply 454 of 683, by ApostolCV
By default multiper was x8.
I change it to x14 but in the system i get same results exept multiper = "x14"
    238.64 KiB
Reply 457 of 683, by red-ray
ApostolCV wrote on 2021-01-06, 16:02:
By default multiper was x8. I change it to x14 but in the system i get same results exept multiper = "x14"
I think you are saying that it always runs at x14 no matter what you select in the BIOS, is this the case?
ApostolCV wrote on 2021-01-06, 16:44:
By the way i found uncorfimed information that Willamate get HT support but was disabled by Intel...
I guess there were ES Willamette CPUs with HT enabled, but I have never come across one or a Xeon DP (Foster) with HT, but there are Xeon MP (Foster MP) CPUs with HT and they also have an L3 cache.
    157.84 KiB
    Xeon MP (Foster MP) CPUs with HT and L3 Cache
Reply 458 of 683, by ApostolCV
red-ray wrote on 2021-01-06, 16:57:
I think you are saying that it always runs at x14 no matter what you select in the BIOS, is this the case? […]
Yes, my friend,no matter which multiper i put.It start at locked -x14
Reply 459 of 683, by Nexxen
Hope it's useful.
    hwinfo.7z
    18.91 KiB
    70 downloads
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
