HWiNFO support of vintage hardware
Reply 440 of 827, by Mumak
Thanks for the feedback.
Reply 441 of 827, by ApostolCV
Hello my friend!
Some time before i get some uncommon stuff. It's a mother MSI 845 PRO V1 (Socket 423) and two CPU for it.
First CPU has SSpec SL57V, second- SL4SG.
First detected by system correct. Butwith second i get some strange results.
In latest version of HW info (6.40 and 6.38) it detects like Quality Samle CPU - QAQ2.
Ok. That's programs are too new. I download older version.
HWinfo Ver.3,35 thinks that's SL4SG,SL4SC. But in the type of graph - Eng. Sample.
Hmm. Much closer to the truth.?
Downloding Hwinfo ver. 1,56...
Ok. Now all is right. SSpec, type...But wait . CPU frequently 11k MHz.
Can it be CPU with edited IHS?
Downwards i add screenshots and results.
Reply 442 of 827, by Mumak
ApostolCV wrote on 2021-01-05, 19:36:
Hello my friend! Some time before i get some uncommon stuff. It's a mother MSI 845 PRO V1 (Socket 423) and two CPU for it. First […]
Hello my friend!
Well, the CPU reports it's an Engineering Sample, hence HWiNFO reported the respective QDF instead of SSPEC.
Please attach the HWiNFO Debug File from the latest version so I can check this in detail.
Also if you're able to get the old Intel CPU Identification Utility you might try if it will report an ES too.
Reply 443 of 827, by ApostolCV
Here it is.
Reply 445 of 827, by debs3759
Mumak wrote on 2021-01-05, 20:37:
Also try the Intel Processor Identification Utility if you can find it somewhere.
It can be found at https://www.techspot.com/downloads/2979-intel … on-utility.html
Not sure if the version on the Intel website works on 32-bit processors
Reply 446 of 827, by ApostolCV
Sorry, that's not the Debug File. See here how to create it: https://www.hwinfo.com/forum/threads/read-thi … g-a-report.241/
Thanks. Hopes now i make right.
debs3759 wrote on 2021-01-05, 20:43:
Thank's for the link. But this do not support 32-bit CPU. =(
Reply 447 of 827, by Mumak
According to that data it seems to me it's an ES.
We'll need to find an old version of Processor Identification Utility for confirmation.
Reply 448 of 827, by debs3759
ApostolCV wrote on 2021-01-05, 21:57:
Thanks. Hopes now i make right. […]
The list says it does. Oh well.
Reply 449 of 827, by red-ray
Mumak wrote on 2021-01-05, 22:02:
I have lots more fidenus in neither of the attached works
Mine is 100% ES for sure, so CPUZ get's it wrong and also failed to sensibly report the RDRAM SPD + multiplier range. HWiNFO failed to report CPU LFM Min which is x8.
file.php?id=99641
Reply 450 of 827, by ApostolCV
red-ray, thank you for old versions of @Intel CPU U@.
Fidenu25 do not see something special.
Am i right?
Reply 452 of 827, by ApostolCV
Seems Intel know something about it.
Reply 453 of 827, by red-ray
ApostolCV wrote on 2021-01-06, 02:26:
Thank you, I guess we need to figure out why. What ratios does the BIOS allow you to set? With my CPU which is an ES I am offered as below, the range is x8 to x23.
file.php?id=99669
Reply 454 of 827, by ApostolCV
By default multiper was x8.
I change it to x14 but in the system i get same results exept multiper = "x14"
Reply 455 of 827, by Mumak
Looks like we need to adjust detection of Production status for Willamette. Problem is Intel didn't disclose this fully even under NDA.
Reply 456 of 827, by ApostolCV
By the way i found uncorfimed information that Willamate get HT support but was disabled by Intel...
Reply 457 of 827, by red-ray
ApostolCV wrote on 2021-01-06, 16:02:
By default multiper was x8. I change it to x14 but in the system i get same results exept multiper = "x14"
I think you are saying that it always runs at x14 no matter what you select in the BIOS, is this the case?
ApostolCV wrote on 2021-01-06, 16:44:
I guess there were ES Willamette CPUs with HT enabled, but I have never come across one or a Xeon DP (Foster) with HT, but there are Xeon MP (Foster MP) CPUs with HT and they also have an L3 cache.
Reply 458 of 827, by ApostolCV
red-ray wrote on 2021-01-06, 16:57:
I think you are saying that it always runs at x14 no matter what you select in the BIOS, is this the case? […]
Yes, my friend,no matter which multiper i put.It start at locked -x14
Reply 459 of 827, by Nexxen
Hope it's useful.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
