First post, by andrzejlisek
INSTALATION:
1.Unzip files to empty directory
2.Run MIXFILE to create starting data file
3.Add to AUTOEXEC section in DOSBOX.CONF (emulated autoexec.bat) following line (files extracted into D:\MIXER):
D:\MIXER\MIXINIT
You can extract to another directory
4.Close and run again DosBox.
USAGE (when you change a sound volume):
1.Enter the directory, where you extracted program
2.Run MIX
3.Change volume:
Left,right Arrows: select channel (device)
Up,down Arrow: Change volume
4.Press ESC
This program was written using Turbo Pascal 7.0. If you want to change, modify, modernize etc., do it and post modified version.
Write review about this program.
    MIXER.zip
    14.87 KiB
    335 downloads
Reply 1 of 2, by priestlyboy
Nifty, 😜. Of course you must run all of this in DOSBox or it gives you runtime erros in WindowsXP.
Two things that really come to mind to make it more useful:
1) Being able to move by increments of like 10 with PgUP/PgDN
2) Moving both Left/Right sides at the same time.
That's it. Nicely done. We've got some DOS programming back. Lol.
Ieremiou
Helping Debug DOSBox.
Reply 2 of 2, by andrzejlisek
This is the next build of Mixer:
Added:
- Changing volume by 10 using PgUp and PgDown
- Changing volume in both channels an the time is now possible
All programs must be run in DosBox 0.62.
    MIXER2.zip
    15.17 KiB
    325 downloads
