First post, by RetroGC
Hi,
can some one create the 4 exe file from this project?
https://github.com/jpmac26/gba-mus-ripper
I'm looking for latest version, but online I could not find the one updated to 2018.
Thank you.
Aldo
Hi,
Thank you.
Aldo
There you go:
Built with cygwin. You need at least Windows Vista to run it. You could give a try Windows XP as well maybe.
Regards. 😎
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Hi
First of all thank you for your help.
I've been able to run both version, but i can see debug option, but no files generated, that's for mid and soundfont.
I'm trying to look for a gba_mus_ripper version able to decode mother3 and others...
Thank you.
Aldo
Maybe those files are discarded during processing because of some mismatching format - I don't know. This application needs to be run under debugger in order to get the information what is going on 😀 Sorry but I don't have enough time.
Still looking for a working version...
Aldo
