First post, by Unregistered
I've got problems running C&C Tiberian Dawn (DOS-Version) with VDMSound - the sound just stutters - please help! mailto:firestormx2k@gmx.de
Note: if you register you will be automatically notified by e-mail when a reply is made to your post.
For the sound: you have two options in VDMSound; if it's the sound card drivers' fault then you have to increase buffering from 75ms or so to probably 750ms or 500ms. If it's the game asking for "too much attention" then you have to decrease the min/maxDMAPeriod pair from 5/15 to, say, 2/10 or 2/5. Also make sure debug logging is disabled.
How fast is your machine, and are you using LaunchPad?
V.
I've got a 1.3 Ghz Athlon on WinXP, i'll try to fix the problem according to what you've told me about the buffer and dma - thanks
