First post, by MaxRideWizardLord
Been searching for hours straight, but couldn't find anything. Most what I could find is to change resolutions to widescreens monitors, but I do need to change it for 5:4, i.e. 1280x1024
No matter what I've tried to change in the options .bat, they all result to be a widescreened, which is ugly and unfitting, leaving huge black bars at top and bottom as well. I doubt that many, if any, of the oldschool games during 90's era were even made with widescreen in mind.
Reply 2 of 4, by MaxRideWizardLord
DosFreak wrote:
Does aspect=true and output = other than surface do what you want?
Nope. Here are configs I use:
fullscreen=true
fulldouble=false
fullresolution=1280x1024
windowresolution=1280x1024
output=ddraw
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74-3.map
usescancodes=true
I have no idea what's the difference between output ddraw, or opengl or whatever, could be that be the case?
EDIT: just a sidenote, aspect=true turns my monitor to 4:3 resoultion, instead of 5:4
EDIT2: it keeps staying widescreen regardless of options for games like HeXen. It really makes me salty.
Reply 3 of 4, by Jo22
In simple words -speaking under correction-:
DirectDraw works natively on Windows XP and earlier. It supports interpolation/scaling.
Since Vista, it is "emulated" and looks *ugly*, there's no direct framebuffer access anymore (except if XP drivers are used *maybe*).
Direct3D works natively on any Windows ands supports scaling & shaders in some DOSBox forks.
OpenGL is OS-independent and supports scaling, interpolation etc.
Surface/WinDIB use raw pixel output. On Windows, they use good ol' GDI.
(Normally, these output methods are handled by the SDL library.)
Reply 4 of 4, by jmarsh
Play with the settings on your monitor, look for something like "wide mode" or "aspect" and try other modes to preserve the original aspect ratio instead of stretching.
