First post, by edumoes
I've had a few of retro PCs in a rack, so the idea it's to share all files/iso/utils needed from a central location. But, using old machine era server. I want to share to Windows / Pure DOS.
Some days ago i've brought 3 siemens primergy 351 servers for like US$ 50. Only one of them boot/post, other was SCO unix installed, and the last one it's used for parts only.
All three servers comes with Floppys, NEC SCSI Cdrom, and Tandberg SCSI tape backup unit.
General specs of servers:
Up to 2 - Socket 5/7 processors, at 200mhz.
512MB memory.
4 PCI (1 shared)
4 EISA slots (1 shared)
PS2 Mouse/Keyboard. Integrated video, serial, parallel, IDE & floppy controller.
Let's start:
All three servers:
371.79 KiB
3 servers
Close Up:
180.79 KiB
close up
First "great" surprise. These 5 1/4 floppys are high density. I think 99% of all HD drives that i've saw are non-black.
138.88 KiB
Teac FDR-55GFR black
Well… 1 Adaptec 2940UW for devices, 1 Adaptec 2944 for externals HVD devices. And 1 Mylex EISA controller (used for connecting bulk of printers). And Intel PCI 10 pro ethernet adapter.
346.62 KiB
Inside before clean.
I've started with the one that boots, SCSI disk are really loud (you know..clack..clack..). So for now, i'm going to use an old 8gb IDE.
Windows Nt4 it's the best option, but Windows 2000 will work fine with +128mb and dual CPU.
Reply 1 of 7, by edumoes
First boot with memory and 2 CPU installed:
Errors.. date & time not set, and EISA configuration error. Replaced CR2032, but EISA error still showing up. (Everytime that the server detects new/removed hardware or CMOS reset, they ask for ECU. (Eisa configuration utility, is a boot disk to set some configurations regarding...well...EISA slots.. ). After Two days of search for the boot disk utility., i've found it on Fujitsu Website (new owner of servers). I've just run the boot disk, check options, bla bla, save. And reboot.
190.16 KiB
boot
After 5 hours of fightning, replaced EDO memorys, turned off EDO detect, etc, i've managed to install Windows 2000 Server... BUT, i forgot to change a CPU option in bios (CPU APIC or MPS mode). And Windows only detect one cpu…, so, reinstall again…and perfect.
551.52 KiB
Windows info
521.99 KiB
Cleaning
Going to finish cleaning today and post final build. Thanks for reading.
Reply 3 of 7, by flupke11
Thank you for this post. It's a great idea to take period correctness to the next level by adding the contemporary servers.
I have a Siemens Nixdorf dual socket 5 mainboard which I presume also come from Primergy servers. It has PCI, ISA and EISA slots.
I never was able to get it working, although current is going through it, as far as I can tell. It came with a extra board to (supposedly) convert the 5V PCI to 3,3V.
275.99 KiB
Reply 4 of 7, by chinny22
I approve of this!!!
If your just using it as a file server for ISO's etc I prefer NT4 as it's install size is much smaller then Win2k. I use my Compaq Prolient 1600 for the exact same thing with that OS.
But Win2k is definitely more "refined"
Another use I'll get around to doing one of these days is installing retro OS's over the network, this post talks about 2003 but is a good starting point.
Retro game/storage/backup server for older systems
But the world needs more duel CPU retro servers!
Reply 5 of 7, by edumoes
SpectriaForce wrote:
So that's a system from ca. 1997 and it has EISA slots? That must be rare.
The motherboard looks standard ATX, is that right?
Sorry for the delay.
Well, there's 2 at alike connector from the power supply, that provides 5v and 12v. location 2
Then there's a 5v cable between location 3 and 15. So this provide 5v to the Vrm, to provide 3v to cpu.
And in location 14, lower right it says 12v, 5v, and 3v. And the connector seems to be atx, but I didn't find if is atx compatible or proprietary.
164.79 KiB
Pdf
Reply 6 of 7, by edumoes
flupke11 wrote:
Thank you for this post. It's a great idea to take period correctness to the next level by adding the contemporary servers. […]
The attachment siemensDualS5_1200.jpg is no longer available
Very nice motherboard, seems to be a high end server. Check this one, is not for sale but Ive took some pictures, it's primergy 500
113.37 KiB
Primergy 500 and my hand
128.65 KiB
Primergy 500 motherboard
Reply 7 of 7, by eisapc
The board pictured looks very much like from a PCD-5T. I own two of these myself. Its an EISA boards with intel NX chipset, limited to Socket 5 Pentiums without MMX.
eisapc
