First post, by pngo
Hi.
I have a few gfx cards on hand for a dimension 4100 with a p3 1ghz/128m and Im not sure which is the most appropriate one for it.
All agp:
-fx5600ultra
-gf4 ti4200 (needs a fan fix cause it was removed from the card since it was not spinning anymore)
-x800xt PE
The dim4100 came with a rage 128pro.
Which card would be recommended? I suspect the x800 and fx5600 are jut overkill but I dont mind unless they will cause issues with games running ok with the p3.
os would be 98se.
