First post, by lausvi
Has anyone managed to get Interlink server working inside DosBox, attached to a real (USB-)serial device in macOS? According to this blog post: https://modelrail.otenko.com/retro/dosbox-ser … -a-real-machine it should work.
I used this to attach my serial device: serial1=directserial realport:tty.usbserial
When I start intersvr, it starts Ok, but it shows no drives being shared. When I start interlnk on the other machine, a baudrate appears at the bottom of the screen, so I believe the communications are working. The client machine interlnk says it has got three drive letters mounted, but they are not readable.
Perhaps somehow interlnk can't figure out a situation where A/B drives are not there, or perhaps it can't calculate the size of drive C? (I did try setting the -freesize -argument to the mounted C-drive, but no dice).
