First post, by algernon
Hi to all, i 've recently acquired a used S2 dreamblaster. installed on a ess audiodrive 1868 i have no sound. volumes are ok...in Duke 3d i select "general Midi" or "wave blaster" but nothing happens.
I tried to change the audio card, another ess AD 1868 but i have the same issue.. maybe i forgot something? some driver required? please help me, for the guy that sold me the s2 doughterbord it's working! thanks
Reply 1 of 2, by derSammler
The wavetable normally has it's own sound channel whose volume you need to set. For ESS, that is AUX2, which is muted by default.
Reply 2 of 2, by algernon
Thanks!! It worked.. The AuxB was =0.
