First post, by root42
I acquired a Model M keyboard, from 1998. Still one of those with buckling springs, model 1391403. It works well, EXCEPT for the backspace key. It feels very mushy and does not jump back quickly. I wonder why that is. Is the spring worn out?
Any ideas on how to fix that?
EDIT: I just put the keycap of the accent key right next to it in there, and it depresses just fine. So I guess it must have something to do with that green guide thingy.
The attachment 08906801-3D7A-49C4-9B16-E2EFBFF08C16.jpeg is no longer available
The attachment D86E55E6-C0CF-4B63-A855-66D675A3DE3E.jpeg is no longer available
YouTube and Bonus
Reply 1 of 5, by dionb
Usually that means the spring is jammed under the keycap. If so you're in luck, all you need to do is hold the spring in the middle of the hole (i.e. by lifting up the front of the keyboard) while you plop on the keycap. Good chance that will fix it.
Alternately, as it's a stabilized key, it could be the stabilizer getting rough. It might need a little bit of lube...
Reply 2 of 5, by root42
I assume now it's the latter. As I wrote in the edit, with a different unstabilized keycap, it depresses correctly. I read one shouldn't use synthetic oil based lubrication. What kind of grease would be ok?
YouTube and Bonus
Reply 3 of 5, by cyclone3d
Not sure I would use grease at all.
I would pop the stabilizer off and clean it and the hole it goes into. Chances are that there is just some dirt or fuzz in there and/or the plastic has worn a bit and has plastic dust in there. Either way, cleaning it should make it work fine again.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 5, by root42
Ok, i will try that, too. Wonder if some pincers will get the stabilizer out...
YouTube and Bonus
Reply 5 of 5, by root42
Update: before doing anything with the keyboard I swapped out the numpad 0-key with the backspace key and noticed that the 0-key works just fine in the backspace position, whereas the backspace keycap is still sticky within the 0-numpad position. So it must have something to do with the keycap itself. I notice that the backspace key has a small ridge in the guide for the buckling spring. Maybe that makes a difference? Other than that both keycaps look identical.
Anyway, I ordered a replacement backspace keycap and a handful of replacement buckling springs, just to be sure, as well as one guide inset. So lets see if that will make a difference.
YouTube and Bonus
