SSTV2 wrote:These Compaq LTE laptops stores part of the BIOS setup and diagnostics on the hard drive, without it you won't be able to boot PC from a hard drive. You must fix that floppy in order to create a BIOS setup/diagnostics partition on a hard drive. I have two such LTE 486 laptops and both suffer from loose rubber belt in a floppy drive. You must get a new belt or make a custom one.
Although correct, this is optional. Compaq created a small - so called - maintenance/setup partition at the front of the drive map. On it was the setup and diagnostic software. Now - it is important to say that the "setup" utility is basically the BIOS setup utility.
Yes, that means that without this maintenance partition present, you cannot enter the BIOS (by hitting ESC/F10) at the startup of the machine. This is basically equivalent of having the bootable setup diskette inserted at boot.
It is, though, not necessary to have this partition set-up/present. It merely means that you can't reach the BIOS without the setup diskette. These models are - however - able to boot from the HDD controller without the setup partition present. I have a Contura still (and had an LTE once) - both do not have the setup/diag partition present, and when necessary to change anything in the BIOS, I do boot from setup diskette.
They do not store the BIOS data in this partition, merely the program to access / change it (BIOS GUI)
