First post, by Guardian_Misterioso
Hi,
I have a problem with DOS version of "Beats of Rage" (BOR) in its Stage 5 when the game tries to load a sublevel just after the elevator zone. At that precise moment, the game returns to the prompt with the following message:
Out of memory!
C:\BOR>
I'm using the SVN-Daum version of DOSBox with its default values. Does anyone know how to fix it? Thanks in advance.
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
try a different build. (like the (non) ECE build of Yesterday80)
Memory layout have changed over the years and daum is known to be a bit unstable compared to other builds.
Water flows down the stream
Reply 2 of 2, by Guardian_Misterioso
I have also tried the ECE build with the same result. However, the official DOSBox website shows a 100% compatibility with this game.
