First post, by FutureTranX
FutureTranX
Offline
Hi!
I'm having two problems with Settlers2 under WinXP prof.
The first is that the game only works in 640x480. If I set it to 800x600 or 1024x780 it quits when starting a map.
The other problem is with the mapeditor (s2edit.exe).
The editor works fine, but when I want to save the map, so click on the save button, it also quits without any error message.
Settlers 2 and Settlers 2 Gold produce the same errors. 🙁
I tryed Dosbox, but it freezes...
If anyone knows a soulution to any of these problems, please write!
Thanks!
