First post, by appiah4
- l33t++
I upgraded my K6-2 from a 430FX to a VIA MVP4 motherboard. K6-2/400 @4.0x100, 128MB RAM, mismatched 12MB Voodoo2s with FastVoodoo drivers. Everything ran fine at first, GLQuake and Quake 2 worked but later I figured benchmarks were off by around 20%. Then I ran 3DMark99 and there was SEVERE stuttering..
It looks to be either a PCI bus BIOS setting issue or a driver issue. I used VIA 4in1 4.35. Is there another version that would be better? Are there any BIOS settings I should check?
Voodoo2s in PCI Slots 1 and 2, maybe I should change slots?
I did not do a clean Win98 reinstall after replacing the Intel board with VIA, maybe a clean install is due?
