First post, by data9791
Is there a patch or fix to play vanilla Daggerfall at higher resolutions? I don't like the way Unity and XL makes the game look, and would just like to play the original at a higher res like 640x480ish+ with the extended view distance mod. I want to run on hardware if possible and not Dosbox.
