First post, by PC-Engineer
Hi,
i am searching for a BIOS for the MIRO Crystal 20SD VL. My BIOS version (1.00.4) does not have sufficient VBE support. Would be helpfull, if somebody can provide a newer version with better VBE support.
Thanks and best regards
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 1 of 8, by kixs
This is a screenshot of my card:
https://i.ebayimg.com/images/g/BmYAAOSwBIVdmF6H/s-l800.jpg
Looks like version is 2.00-01. Would NSSI dump the video BIOS correctly? I don't have any special equipment.
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 4 of 8, by BastlerMike
Reply 6 of 8, by Anonymous Coward
Crystal 20SD can come with either an S3 864 or an 868, right? Do you think the BIOSes are interchangeable?
Reply 7 of 8, by PC-Engineer
No, at least the VLB version is only available in with Vision864 and i think the PCI Version too. But there are two PCB versions of the VLB version, the older with AT&T DAC and the newer one with S3 DAC. I have the older one - will see what happens ... 😉
Reply 8 of 8, by Anonymous Coward
Are you certain? I'm pretty sure I've seen Vision868 versions of the 20SD. Perhaps they had slightly different model numbers, but I thought the PCBs looked damn near identical (kind of like the Stealth64 DRAM and Stealth64 Video DRAM).
