First post, by mallensw
Currently I am requiring assistance in getting a proper serial mouse working with windows 95 or 98se. This is what I know thus far. The motherboard is a Zida 4DPS. The mouse is a 2 button (no wheel) beige MS proper serial (no adapter) mouse that works. The COM ports are enabled in the system bios and set to COM1 3f8 IRQ4 COM2 2f8 IRQ3. In both windows 95 and Windows 98se I get the usual "windows did not detect a PS/2 mouse, its now safe to attach a serial mouse" screen when windows loads. I plug it in, press the o.k button, windows finishes loading, and the mouse does not work. Currently I have windows 98se installed. I have also loaded ctmouse in the autoexec and when i boot to command prompt only the mouse will work in DOS. If I boot into windows safe mouse, mouse does not work. In device manager it shows both com ports and the correct addresses and IRQs that are shown in bios. When I run the add new hardware in control panel windows finds nothing. This is baffling me to know end. This mouse will work DOS but not windows. I have also tried to manually install the MS standard serial driver in the device manager and still no result. Lastly I have also confirmed that this is not a bus mouse. Not sure if anyone has come across this issue before but any assistance will be greatly appreciated.
Reply 1 of 12, by lost77
I might be wrong about this but I think you should plug it in before starting the computer. This is not USB after all.
Reply 2 of 12, by mallensw
I have tried many times still to no success. The only other thing I think of is the pin outs and how the port is wired but this is strict a guess. Thanks for your input though.
Reply 4 of 12, by derSammler
His mouse works in DOS, so it's certainly not the port connector.
Do you always load the mouse driver for DOS in autoexec.bat? If so, try without. It may conflict with Windows.
Reply 5 of 12, by Tiido
Whoops, I somehow missed the working in DOS part. I'm not sure what is going on that windows won't work, since two different ones behave same.
Reply 6 of 12, by mallensw
Guys, thanks for the assistance and Tiido thanks for the link pin out discussion. Not sure if this is the real issue or not but I have tested the pins on my current port and found on a ebay for 5 bucks a port that is pinned the other way. Hopefully the new port will a inexpensive 5 buck fix, fingers are crosses and will update once the new port arrives.
Reply 7 of 12, by mallensw
Well guys, sorry for the very late posting but the new port did arrive and did not solve the issue so I am still trying to figure this out.
Reply 8 of 12, by Horun
Maybe the DOS mouse driver is conflicting with Win9x driver. Have you tried a MS mouse driver for DOS ? or try REM out the CTmouse in Autoexec and reboot then load Win9x and see what happens...
Reply 9 of 12, by mallensw
So the I started poking around in the Bios and I seen something in there for power management. For the sake of science (to see what would actually happen) I disabled it vaguely remembering that in a pure windows setup windows manages power. To my surprise when windows 98se loaded I now a a fully functional working serial mouse.
Reply 10 of 12, by rasz_pl
was it ACPI by any chance? ACPI is unfortunately called Advanced Configuration and Power Interface, but it mostly about letting OS manage resources (interrupts, address mappings).
TLDR: you had wrong interrupt selected before or your board was one of the ones with bad/corrupted ACPI table. Turning ACPI off switched resources management to the old hardcoded way.
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 11 of 12, by mallensw
rasz_pl I believe you are correct. This was on a OEM Gateway 440lx motherboard using it's original 1997 bios. I recently found an updated/final bios on the Gateway website using the Wayback archive. Flashed it, loaded the bios defaults which left ACPI enabled. and had no problems.
Reply 12 of 12, by quigonhu
A serial mouse?? Wow, that just reminds me the good old days when I was a fresh new, sensitive and weird high school idiot~~~^_^
Well, in my impression, I really didn't have much trouble with the serial mouse, neither under the DOS, nor the Window9x. Of course it was 1998 and the motherboard's chipset was 440LX.
Since it can be used under the DOS, I don't think there's hardware conflict. Try to reinstall the whole system beginning from the "FORMAT C:\", then install the DOS, then the optical drive and the mouse driver, then the WINDOWS98, see whether the mouse is functional during the installation.
If you don't have other serial device and the COM ports are not occupied by other device or program, the mouse should be well used.
