First post, by Cobra!
- Member
So I decided to play through the Sam & Max Telltale games again, and I've been having a problem with running Season 2. The original exe requires the exe and makes the disc drive go crazy. Turns out it was using SecuROM.
So I tried an exe that doesn't require the disc, and all that shows up is a black screen and just hangs there.
Resource Monitor comes up empty and none of the compatibility modes I've tried have worked, and that's all the info I have.
What do I do?
