First post, by that1crzywhtguy
I'm really scratching my head over this one. I can't figure out what could be causing this to occur.
I installed WC, and set it for MT-32. When I try to open WC, it says "expanded memory detected," but then it just hangs there. If I set the configs for sound blaster, then the game boots and runs fine. Switch it to back to roland, and again, it is sticks.
I've tried reinstalling, I've checked all the configuration of my awe32, and nothing is helping.
Also my mt-32 setup works fine in every other game I've tested it.
I would be vary grateful for any help with this one!
Reply 2 of 5, by CrossBow777
How long did you wait? Also when you start the game and you see that message, look at the MT-32 and see if the Midi messages light is blinking. It could be that the game is still initializing the MT-32 and you might not be waiting long enough?
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 4 of 5, by thorsten.iwanowski
Hi there
I face a similar problem with starting WC I and WC II on a recent WIndows 10 notebook.
The installation of the SoftMPU did unfortunately not work given my PC only allows 64 bit software to be installed.
Do you guys have any resolution for that please?
Reply 5 of 5, by BEEN_Nath_58
thorsten.iwanowski wrote on 2022-09-22, 22:34:
Hi there […]
Hi there
I never used SoftMPU but as far as I remember isn't it a DOS TSR? And not anything for Windows?
