First post, by jimsikra
Having issues running Darkspyre with DosBox:
"Warning: file C:\games\darkspyre\HORIZON exists and failed to open in write mode. Please remove write-protection."
I've removed write-protection multiple times, and it still doesn't work. I have tried running it with both the Darkspyre files from myabandonware as well as my own files from the original 3.5" disks.
Any advice?
Reply 2 of 6, by jimsikra
Nope. Not sure what to do
    103.13 KiB
    340.64 KiB
Reply 4 of 6, by jimsikra
Good catch. It's the same issue whether I use my original files or the ones from the abandonware website (those are the two folders).
    93.59 KiB
Reply 6 of 6, by krcroft
C:\games\darkspyre\ was probably created from a process that got elevated privileges (and therefore applied those ownership attributes to the sub-directories and files), where as your DOSBox executable process is probably being launched as your non-elevated user.
Try launching DOSBox as an administrator; if that solves it then you can work on changing the ownership of the entire C:\games\darkspyre\* tree back to your user account.
