First post, by PKFreeZZy
Hello,
I'm somewhat desperately trying to figure out what's going on with my GeForce2 Pro. Recently it's been doing weird things, such as displaying horizontal screen glitches I like to call "jitter" on the BIOS POST screen, in Windows 2K and XP at the monitor's native resolution and in certain full screen programs. Unreal Tournament also flickers sometimes, but on a bigger scale. On top of that, 3DMark2000 sometimes crashes with the drivers I'm using (?), but swapping the Pro out for an MX resulted in 3DMark always finishing. I haven't tested the other cases of the jitter yet.
I currently know 2 culprits I can trace the source of the issue down to: the motherboard (P2B Rev 1.04) polls 3.6, 12.5 and -12.3 volts on the respective rails which affects the I/O or AGP voltages, or the GPU is dying (?!).
Could I please get some advice regarding this issue? I don't feel like paying for another Mid-Range GF2 if I don't have to, so I'd appreciate any help that comes along.
Thanks in advance!
My Windows 98 PC: Slot 1 Pentium III 600 (Katmai) | 256MB PC133 SDRAM | 64MB Leadtek WinFast GeForce2 Pro | Creative SB16 CT2230 | Intel PRO/100+ with Alert on LAN* | 18.64GB Seagate ST320011A | Corsair CX430 | ASUS P2B Rev. 1.04
Reply 2 of 9, by PCBONEZ
You missed +5v.
3.3v and -12v are out of spec high.
+12v is barely in spec on the high side.
The PSU is your prime suspect but that may not be the only (or the real) problem.
Bad caps can fail towards shorting internally and one on +5v causing excess +5v current would cause the other rails to go high as the PSU tries to compensate.
If that's the case then +5v should be on the low side if in spec at all.
That makes the PSU try to raise the +5v voltage and the other rails are affected too.
I've seen that exact scenario a number of times.
Look for bloated caps (on the mobo and in the PSU) - but not all bad caps bloat.
If none then try a different PSU.
If the issue doesn't go away look for other problems.
31.19 KiB
Reply 3 of 9, by derSammler
-12V:
is: -12.3V, allowed range: -10.80 to -13.20V
+12V:
is: 12.5V, allowed range: +11.40 to +12.60V
Both voltages are fine and fully within specs...
+3.3V may not, but most cheap voltmeters are off by 10% or more anyway, especially for very low voltages. So unless he uses a good, calibrated voltmeter, I'd guess the PSU is fine.
Reply 4 of 9, by PCBONEZ
derSammler wrote:
-12V: is: -12.3V, allowed range: -10.80 to -13.20V […]
-12V:
+12V:
Yeah I read -12v wrong but that's for biasing not power so it doesn't matter very much.
A properly working PSU at idle should be in the middle of the range not right at the edge so whether you like it or not those voltages raise red flags.
Reply 6 of 9, by PCBONEZ
shamino wrote:
If you're using the BIOS health monitor to read the voltages, then the values aren't reliable. Many boards will give some wild readings that don't match what you'd find with a multimeter.
Yes - This.
Reply 7 of 9, by PKFreeZZy
Wow, sorry for being late with my reply. I didn't get any answers in the first couple days, so I gave up on it.
I have, in fact, checked it with a different PSU, but that was also on a backup motherboard. Didn't get any 3DMark crashes there, but the horizontal flicker was still kind of there. I now have a new WinFast GeForce2 Pro which doesn't flicker, but 3DMark still crashes. I suppose there are some bad caps hiding on the motherboard, as it behaves somewhat oddly in certain aspects (sometimes the boot memory test lags and the optical drive isn't detected by the BIOS after soft resets).
Also, the hardware monitor in the P2B's BIOS is pretty accurate, except for the CPU VCore which displays 2.1V. Using CPUID HWMonitor, I was able to determine that the 3.3V rail does indeed operate at 3.63-3.65 volts and the rest of the values are also as shown by the BIOS, unless the CPU running at 2.06V most of the time rather than 2.05 counts as unusual.
Reply 8 of 9, by shamino
Software utilities still read from the same sensors that the BIOS does, so they will say the same thing (barring a shift due to system load, or because the software isn't interpreting the data correctly). But the accuracy of motherboard sensors is generally poor, sometimes they're close but sometimes they're way off. There's no way to know without an independent measurement.
The 3.6V reading in particular is concerning so I'd want to verify it with a multimeter. If it really is 3.6V then I'd keep any valuable hardware away from that setup.
+5V might be low to the same degree that 3.3V is high, as PCBonez alluded to. Some PSUs are group regulated in a way that causes this to happen.
5V(red) and 12V(yellow) can be measured on an unused drive power connector. 3.3V can be backprobed on the ATX motherboard power connector (orange wire).
Reply 9 of 9, by PKFreeZZy
Well then, I guess I don't need to be concerned about the PSU; I know for a fact it operates properly because I checked it on a modern LGA1156 motherboard and the 3.3V line delivered 3.392 on it; didn't know the 5V rail is also almost out of spec, but my the other systems I've used with this PSU all worked flawlessly.
Could this really be caused by the capacitors? They seem fine, there's no leaked electrolyte nor any bulging ones, though I've learned my lesson with the "backup motherboard" I mentioned as that one sometimes behaves strangely as well and its caps also look fine.
I've considered replacing the ones on the P2B with polymer capacitors since I think there's no other source of trouble than ancient Cylinder Town.
